Media Composer 3.1 Editing P2 720 30N and HDV 1440 X 1080
Alvin Lowery
on Jul 17, 2014 at 6:55:26 pm
I wiil be editing P2 720 30N and HDV 1440 X 1080 in Media Composer 3.1. I will be using multicam mode. Can these 2 formats be edited together in Media Composer 3.1 in the same sequence?
Shane Ross
Re: Media Composer 3.1 Editing P2 720 30N and HDV 1440 X 1080
on Jul 17, 2014 at 11:14:14 pm
To group any footage, the codec, frame rate and frame size all need to match. So you need to transcode the media to a common frame size and format....say all DNxHD 115 1920x1080 29.97. Then Avid will allow you to group the clips.
Test with smaller clips to ensure you get the settings right.
Shane
Little Frog Post
Alvin Lowery
on Jul 18, 2014 at 7:40:57 pm
