avid media composer video problems
Cristina Frunza
on Jul 2, 2014 at 1:16:43 pm
Hello
I have a problem with Avid media composer
i record on minidv casette sony hd 1080i and now i want to load them with a sony dvcam.
The problem is that i can hear audio but i can't see the video on the monitor.
When i push the esc but to stop the capturing, i can see both video and audio and are oky.
The problem is why i can't see the video when is capturing? And sometimes the capturing is stoping for no reason.
Please if is someone knows what is the problem ?
Thank you.
Cristina (sorry for my bad english writing)
Shane Ross
Re: avid media composer video problems
on Jul 2, 2014 at 5:16:22 pm
The tape was shot as HDV...you need an HDV deck to play it back. A DVCAM or DV deck won't do it, as they are SD only. You need specifically an HDV deck
Shane
Little Frog Post
Cristina Frunza
on Jul 2, 2014 at 6:00:22 pm
My sony dvcam work both sd and hd. I put it on hd. It capturing but i can't see the video on the monitor...
Shane Ross
on Jul 2, 2014 at 6:47:39 pm
Ah...so it is an HDV Deck.
Are you in an HD project?
Shane
Little Frog Post
Cristina Frunza
on Jul 2, 2014 at 6:48:44 pm
Yes 1080i
John Pale
on Jul 3, 2014 at 7:31:39 pm
Are you sure the frame rate of the video on the tape matches your project...
For example, a tape shot at 1080i/50 will play just fine on the deck, but if you are in a 1080i/59.94 project, it won't capture.
Cristina Frunza
on Jul 3, 2014 at 7:48:24 pm
I am in 1080i/50. I can't see the problem :(. Is the first time when i have this problem
grinner hester
on Jul 5, 2014 at 3:24:23 pm
you have to make sure the deck has been toggled to HDV from DVcam.
Andrew Kimery
on Jul 6, 2014 at 12:20:47 am
In the Capture Settings is the "Display incoming video in the client monitor" turned on?
