How to export an 8 bit 4k 4:2:0 file into a 10 bit 1080p 4:4:4
Lucien Newell
on Jun 21, 2014 at 7:00:17 pm
I've been playing around with different workflows with the new Panasonic Gh4. So far I have been able to export 8 bit 4k 4:2:0 files into 10 bit 4:2:2 1080p files. Though I'd like to be able to export into a 4:4:4 subsampling rate.
Shane Ross
Re: How to export an 8 bit 4k 4:2:0 file into a 10 bit 1080p 4:4:4
on Jun 21, 2014 at 7:31:24 pm
You'll have to export as ProRes 4444 then. There is no DNxHD 4444 yet. To my knowledge.
The GH4 footage, how did you bring that into Avid? AMA and Transcode?
Shane
Little Frog Post
Lucien Newell
on Jun 21, 2014 at 7:52:49 pm
Great, I don't have a mac :]
I linked through AMA, then transcoded to compressed proxy files, then either relink to AMA files in Avid when picture is locked or send an AAF timeline to Resolve for cc and then export.
Shane Ross
on Jun 21, 2014 at 7:58:10 pm
Yeah, Resolve is the way to go.
Shane
Little Frog Post
Pat Horridge
on Jun 22, 2014 at 8:30:03 am
No 4k in Avid (yet) but you can work at 444 switch the format of the project to RGB and you can choose 1:1 10bit or Dnx444. But little point bumping 4:2:0 footage up to that. You just make bigger files.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Lucien Newell
on Jun 22, 2014 at 7:37:06 pm
Ok, it turns out I didn't scroll down enough to see the dn x hd 444 option :]
I was reading this article:
http://www.eoshd.com/content/12140/discovery-4k-8bit-420-panasonic-gh4-conv...
Apparently converting 4:2:0 4k files into 4:4:4 1080p could benefit the footage because of all the extra pixel information in 4k.
"The way this works is quite technical but it essentially amounts to using the extra pixels present in the 4K files to rebuild the lost colour information. Neighbouring pixels are summed to create a super pixel with a greater bit depth and better sampling. It requires a lot of processing power and a finishing codec good enough to store the extra colour data (10bit 4:4:4, with CineForm and ProRes being suitable choices) which is why the camera doesn’t do it internally. It does require a transcoding step in post but the increase in quality over the 8bit internal 1080p codec will be marked. The message is clear. Even if you’re working in 1080p, shoot 4K on the GH4 if you want the best quality."
Though I don't know enough about codecs and the science behind all of it to really make a judgement. Thought I'd try it out.
John Pale
on Jun 22, 2014 at 3:37:39 pm
[Shane Ross] "There is no DNxHD 4444 yet. To my knowledge.
It exists now. I think it came in with v7. Switch project to RGB.
