Open Media Composer 4 Projects in Media Composer 8?
Jessica Muth
on Jun 13, 2014 at 12:17:17 pm
Hi All,
Has anyone tried to open older projects and assets in Media Composer 8 that originated from old versions of Media Composer, such as version 4? I have a client that wants to upgrade his system and use Media Composer 8; however, he still uses Media Composer 4. So we want to make sure that if he upgrades to version 8, opening projects and assets won't cause any issue.
I've found older posts of a similar question of opening version 4 projects in version 6 of Media Composer, but I do need a definitive answer about doing this for Media Composer 8. Of course, I can't get Avid on the phone because we don't have a support code, so I'm doing my best to research the issue to be able to confidently tell them yes or no.
Any help you can provide is great. Thanks!
Reference: http://www.dvinfo.net/forum/avid-editing-family/508696-import-old-media-com...
Shane Ross
Re: Open Media Composer 4 Projects in Media Composer 8?
on Jun 13, 2014 at 4:37:55 pm
They will open fine. Note that when you open the sequence, Avid will ask to update it...click yes. And a copy of the sequence will appear in the bin, with a .updated on it.
Shane
Little Frog Post
Pat Horridge
on Jun 14, 2014 at 8:23:35 am
Yes V8 will open earlier projects. Also you will be on support with V8
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Jessica Muth
on Aug 7, 2014 at 1:50:52 pm
You two are great. Thank you. Avid could not tell me this directly!
Jessica Mantheiy
