Spreadsheet Data (shoot notes) to avid bin columns
David Hudson
on Jun 10, 2014 at 1:28:52 pm
I have shoot notes in a spreadsheet, scene, take, notes, description, etc Is there a way to import this data and have the info as columns in a bin
Richard Sanchez
Re: Spreadsheet Data (shoot notes) to avid bin columns
on Jun 10, 2014 at 2:51:09 pm
Export your spreadsheet as a tabbed delimited text file. Then run it through Avid Log Exchange to convert it to an ALE file. Then you can import it. I usually set it to "Merge with known master clips" in your import settings.
If you're on 7.0.3 it will merge that data without removing any custom metadata on those master clips. If you're on pre 7.0.3, merging could remove any custom metadata you have on those clips, so be aware of that. Michael Phillips describes it well here.
http://24p.com/wordpress/?p=132
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
David Hudson
on Jun 10, 2014 at 3:08:59 pm
Seems simple. But I have tried making a simple shot spreadsheet in several apps (numbers, openoffice, textedit) I see no save as "tabbed delimited text file"
any thoughts there?
Richard Sanchez
on Jun 10, 2014 at 4:01:34 pm
Unfortunately I can't speak for those programs. FileMaker Pro is popular for this purpose, and I've done it with Excel.
Richard Sanchez
Los Angeles, CA
Michael Phillips
on Jun 10, 2014 at 7:28:34 pm
You need to do a "save as" from Excel as Tab. Make sure that all the column headers match exactly with uppercase, lowercase, and spelling. Here is the most recent Avid metadata whitepaper that exists, but is either unknown or hard to find. it will give you an idea of what each column is for and at the end how an ALE header should be constructed. AvidLogexchange as mentioned will take in a TAB file and create an ALE file after asking a few questions. Like about the film stuff. Just make it 35mm. Also make sure to keep a copy of the ALE program as v8 has removed both AvidLogExchange and MediaLog.
http://24p.com/wordpress/?p=101
Michael
Richard Sanchez
on Jun 16, 2014 at 2:35:20 pm
WHAT?!?! They got rid of Avid Log Exchange? Can you still import ALE's from Resolve or whatever dailies system you might be using to merge relevant metadata?
Richard Sanchez
Los Angeles, CA
Michael Phillips
on Jun 16, 2014 at 2:53:37 pm
They no longer ship the application AvidLogExchange, but the ALE file format is still supported seeing as it is the only way to easily get metadata into Media Composer other than AAF (which is not easy).
Michael
josh granger
on Oct 31, 2014 at 6:30:56 pm
Been trying to import spreadsheet data into MC 8.0 myself, and this thread keeps coming up when searching for ALE. It's crazy that Avid doesn't ship ALE any more, when I called tech support and asked them about it (after a lot of hold time), they finally advised me to download MC 7.0.4 and get ALE from that. I've posted it if anyone else is searching for it, hope forum rules allow for this.
This is the Mac version:
http://joshgranger.com/temp/Avid_Log_Exchange.zip
Michael Phillips
on Oct 31, 2014 at 8:09:24 pm
I blogged about the loss of ALE application here in August:
http://24p.com/wordpress/?p=197
And how it can be used here:
http://24p.com/wordpress/?p=200
Michael
