Setting up for a project shot on film
Scott Davis
on May 29, 2014 at 5:44:13 pm
I've worked on projects that where shot on film; but posted and delivered in video. I have a short film now that might want to end up back on film. What should I be aware of while setting this project up? Is there a good resource that explains the workflow for film to Avid to film?
Thanks for any insight or thoughts.
Scott Davis
View Scott Davis's profile on LinkedIn
Michael Phillips
Re: Setting up for a project shot on film
on May 30, 2014 at 1:33:26 am
The Avid user guide has a lot of information on managing film based projects with the intent of going back to film.
For starters, you're first going to create a project that matches the video format/resolution and frame rate - for example, 1080p/23.976. Then select the film format in order to generate lists.
Michael
Scott Davis
on May 30, 2014 at 4:54:55 pm
Thanks Michael,
Quick question: If footage has already been imported in (at the correct format/resolution) but into a project where the film option was not selected; can I create a new project with the film option selected and bring the bins into this film project?
Scott Davis
Michael Phillips
on May 30, 2014 at 5:07:43 pm
Yes, you should be able to.
Michael
