metafuze
geraint pari huws
metafuze
on May 27, 2014 at 2:34:12 pm
Where am I going wrong, I'm importing file sequences via metafuze, process is fine when I import 1080 185 10bit, but, when I select uncompressed 10bit, the new transcoded mxf files roll horizontally. Any suggestions gratefully accepted.
Michael Phillips
Re: metafuze
on May 27, 2014 at 3:16:07 pm
I need to go back and look at MetaFuze. It has been a loooong time since I've used it. Basically since Resolve was free and it makes native MXF media. :)
But in your case, you're trying to make uncompressed MXF which is not part of the Resolve export functions, so I can see your need to use MetaFuze. The last time I installed it, it wouldn't launch, so when I get time, I will try again.
Michael
geraint pari huws
Re: metafuze
on May 27, 2014 at 3:33:48 pm
I use resolve, but as a one(ish)stop shop, metafuze is fairly simple, and scans dpx folders really efficiently
