Audio Suite reverb won't work on music audio.
dan crouch
on May 17, 2014 at 11:11:21 am
Hi Guys,
I am running a project with an audio sample rate of 48Khz.
I am using some music tracks from i tunes which are 44.1 Khz
They are set to convert as they play which works fine, but when I try and put a reverb effect on them
there is an error and it doesn't work due to the sample rate.
I am not sure how to get around this, any help would be gratefully received.
Avid 6.5.3
Mac
Cheers,
Dan.
Michael Phillips
Re: Audio Suite reverb won't work on music audio.
on May 17, 2014 at 1:39:47 pm
If you right click the clips in the bin and choose convert to 48kHz, do they now start working?
Michael
dan crouch
on May 19, 2014 at 8:27:08 am
Thanks for the post's
I have managed to convert an audio track from 44.1 Khz to 48Khz to enable reverb to work in Audio Suite.
The problem is it will only allow me to render the reverb effect to another external drive. Not the main drive with the MXF's on it.
In fact if I put reverb on any audio file, I can only render to another extrnal drive. My mac hard drive is grayed out and an error 'Exeption: Operation not supported, filename:/Volumes/work/Avid MediaFiles/MXF/3?creating/creating7'
The Extrnal drive with MXF's is called 'work'
Any further help on this would be great.
Dan.
Michael Phillips
on May 19, 2014 at 6:39:31 pm
I don't know what to say on this one... do you have the internal drive filtered out?
Michael
dan crouch
on May 19, 2014 at 6:58:50 pm
Thanks for post Michael.
I don;t know if I have drive (s) filtered out or not.
I have just upgraded, is that an Avid setting or a Mac setting?
Cheers,
Dan.
Michael Phillips
on May 19, 2014 at 7:07:17 pm
Settings->Media Creation. There are check boxes on the first tab for various filtering options.
Michael
