Panasonic GH4 in Avid
Benjamin Sidoti
on May 15, 2014 at 7:57:17 pm
Just curious if people have been able to work with the GH4 in Avid natively yet.
Shane Ross
Re: Panasonic GH4 in Avid
on May 16, 2014 at 4:43:47 pm
Well, you do know that Avid doesn't do 4K yet, right? So you might be able to AMA in the footage...but it won't be 4K. Largest project you can have is 1080.
Shane
Little Frog Post
Benjamin Sidoti
on May 16, 2014 at 4:47:46 pm
Right, I'm working with 1080p.
iPhoto will recognize it, but not Avid. Huh.
Shane Ross
on May 16, 2014 at 4:56:22 pm
There's this link...
http://community.avid.com/forums/p/127455/729270.aspx
You can't AMA LINK to the individual files? Try the Panasonic plugin...
Shane
Little Frog Post
Shane Ross
on May 16, 2014 at 4:55:05 pm
I see that it shoots MOV files as H.264...and MP4 as H.264...as well as AVCHD (don't shoot that format...first off, it's SD, second off, AVCHD sucks). The H.264 files should AMA fine. You'll have to AMA via FILES, not AMA VOLUME...as there is no AMA plugin for this camera that I can find.
Shane
Little Frog Post
Benjamin Sidoti
on May 16, 2014 at 4:56:23 pm
That's what I thought, thanks, Shane!
William Busby
on May 17, 2014 at 7:31:30 am
[Shane Ross] "...as well as AVCHD (don't shoot that format...first off, it's SD, second off, AVCHD sucks)"
SD? Say WHAT? :D
Shane Ross
on May 17, 2014 at 5:52:48 pm
Whoops, sorry. The camera does record AVCHD in an SD format...but it does in HD as well. The format still sucks.
Shane
Little Frog Post
William Busby
on May 17, 2014 at 6:49:37 pm
that's just silly :D The GH4's SD is MP4. But I do agree... AVCHD blows
Nicolas Bori
on Jan 19, 2015 at 11:34:35 am
Hi guys,
I tried using the link to AMA file then transcode workflow but I am having serious issues with importing/transcoding.
Until now I have used Canon T5i .Mov H264 files and never had a problem importing. But I just got the Panasonic GH4 and it is a nightmare, if I set more than one file to import/transcode, it will freeze and crash the Avid.
So far I can only import files one a time, and it stills crashes some times. It is extremely time consuming and frustrating.
I was wondering, am I the only one having problems importing/transcoding GH4 files?
I have GH4 mov h264 1080 29.97 clips. On a 29.97 timeline.
Any help will be greatly appreciated.
Nicolas
My specs
Avid Media Composer 6.5.4.2 / MacBook Pro / OSX 10.9.3 / Processor 2.3 GHz Intel Core i7 / 8GB Ram 1600 Mhz DDR3 / Hardrive SSD 256GB
