Avid mc6 pc & Avid mc7 mac compatability
dan crouch
on May 12, 2014 at 9:01:58 pm
I am cutting a tv show at home on a mac book pro using Avid mc3. (yes 3!)
At work I am using mc 6 on a pc.
It's been fine but there have been a few glitches which are a bit scary with deadlines looming.
My question if anyone can help is if I buy Avid Media Composer 7 (mc6 seems tricky to buy) will it be compatible with the Media Composer 6 at work.
Any help would be very much appreciated.
Thanks.
Shane Ross
Re: Avid mc6 pc & Avid mc7 mac compatability
on May 12, 2014 at 9:19:51 pm
What version of MC6? I know that if you make a bin in MC7, it can only be opened by specific versions of prior MC versions. And don't use things that are in MC7, but not earlier...like Frame Flex
Shane
Little Frog Post
Robert Pitman
on May 13, 2014 at 9:59:12 am
From memory, Media Composer 6.0.4, Media Composer 6.5.4.1, Media Composer 7.0.4 play nice with Bins and therefore should play nice with AAF to some level (as stated avoid FrameFlex - or test how Media Composer 6.0.4 opens it?). Avid does have knowledge page with these details.
Cheers,
Robert
dan crouch
on May 15, 2014 at 11:12:32 am
Thanks very much for your post's.
I shall go with the new software and see how it goes.
Cheers,
Dan.
