Avid MC 7.0.3 AMA linked prores 444 file playback problem...
Togan Gokbakar
on May 5, 2014 at 1:07:49 pm
Hello
I have a very frustrating problem. I updated my Avid to 7.0.3 from 7.0.2
and after update my AMA linked Prores hd 444 files started to play slowly , but sound is okay. If I transcode a clip it works fine but AMA linked files have slow playback. With 7.0.2 they were playing fine.Any ideas? (Mac btw)
Brian Gavin
Re: Avid MC 7.0.3 AMA linked prores 444 file playback problem...
on Mar 18, 2015 at 10:51:59 pm
I'm having the same issue in Avid 8.2. My AMA linked ProRes HD 4444 files playback slowly and audio becomes unsynced. If I transcode to MXF they play fine.
What did you do to resolve your issue?
Brian Gavin
on Mar 18, 2015 at 11:52:42 pm
I'm having the same issue in Avid 8.2. I AMA linked to ProRes HD 4444 and then when I played the AMA files back in AVID the video was choppy and the audio lagged behind the video.
When I just transcoded the original ProRes file to MXF it played back fine.
Did you resolve your issue? Also using mac.
