AVID won't play because of Ultrastudio mini monitor.
Christopher Young
on May 2, 2014 at 9:28:32 pm
I'm getting a pretty irritating error currently.
AMD_COREAUDIO_FAILED_TO_SET_SAMP_RATE
I'm going out to a client monitor, but AVID can't seem to get it through it's thick head to play anything while I'm plugged into the monitor.
If I boot up AVID and then plug in the monitor, then I can play audio but not get any video signal...this is stupid.
I know it's not my black magic device because client monitoring works in every other freaking program.
Every time I hit play I get that error ( making it impossible to watch down anything ).
HELP!
Shane Ross
Re: AVID won't play because of Ultrastudio mini monitor.
on May 2, 2014 at 11:21:14 pm
Do you have the most current drivers for that unit installed? What version of Avid are you running?
Shane
Little Frog Post
Neil Goodman
on May 3, 2014 at 4:29:31 am
dont use the most current drivers.. 10.0 and even 10.1 are screwed for Media Composer .
Desktop video 9.9.3 is the best working driver blackmagic has put out. download that one and you should be good to go.
Christopher Young
on May 3, 2014 at 4:32:21 am
Thank you very much. Black magic just sent me a very similar email!
I'm glad it's something this simple. I spent all day doing PRAM and preference resets.
