XDCAM import problem
stig olsen
on Apr 22, 2014 at 10:44:21 am
I just got some XDcam material on an external HD.
Its folder structure is as following; PROAV/CLPR/C001/C001A01.mxf and so on.
I have the latest AMA drivers, and I have tried both AMA linking and regular import. Nothing works. Any idea?
Stig
AVCHD MSP Plug-In Avid Technology, Inc. 1.3
AVCHD MVP Plug-In Avid Technology, Inc. 1.3
Avid MXF MSP Plug-In Avid Technology, Inc. 1.1
Sphere (5975 1.3.6367424) Avid Technology, Inc. 1.1
QuickTime Plug-In Avid Technology, Inc. 1.3
AS-02 Plug-In Avid Technology, Inc. 1.2
AS-11 Plug-In Avid Technology, Inc. 1.0
MSP_MXF Plug-In Avid Technology, Inc. 1.9
MVP_MSP_SonySRDeck_64bit Sony Corporation 2.2013
WaveAiff Plug-In Avid Technology, Inc. 1.0
MVP_MSP_SonyXDCAMEX_64bit Sony Corporation 1.7053
MVP_MSP_SonyXDCAM_64-bit Sony Corporation 3.2011
Michael Phillips
Re: XDCAM import problem
on Apr 23, 2014 at 11:33:01 am
I usually try linking via clip first before folder to make sure the correct Sony AMA plug-in is being used. So in yor example, use the link to file and select "C001A01.mxf " directly with each of the plug-ins. Once you know you can link to it, note which one you are using then use the "folder" version of the AMA plug-in and work your way backwards in the folder structure until it works. There is only one level of hierarchy that will work and I never remember which one, so I do the different levels until it does. My guess is either the PROAV or the CLPR folders. Also make sure there are strange characters or slashed (/) in any of the folder names, but from your example, it does not seem to be the case.
Michael
