MusID
Greg Cohan
MusID
on Apr 15, 2014 at 12:26:20 am
Michael..
http://www.mus-id.com
If this works it is brilliant and I will pay for it.... and about time someone realized we need that info for metadata not only in edit but after edit.
What happens if there is an effect on the audio?
I only beg you on my knees to make an AAF reporter that lets me make the same sort of reportable file for archival acquired footage...
Greg
Michael Phillips
Re: MusID
on Apr 15, 2014 at 1:58:30 am
Greg -
The AAF reporter application will ignore all effects, and just list them in the resulting file with START, END and duration of the sequence timecode along with other metadata that came with the file.
I hear you on the stock footage reporting application. The question will be whether I will get granted an AMA license to do that seeing as Avid has a stock footage integration and report as long as you purchase from within the Marketplace.
I blogged about a workaround for EDL's:
http://24p.com/wordpress/?p=62
Michael
Michael Phillips
Re: MusID
on Apr 15, 2014 at 1:27:22 pm
We've also just uploaded some preset bin settings for mus.iD metadata columns that are free to dwonload. If you're using the plug-in you have a head start, if you're not, you can see what you're missing. :)
Michael
