Alternative to "nested" audio
Adam White
on Apr 9, 2014 at 5:28:52 pm
I have several audio clips in my timeline that I have balanced against one another, but now would like to boost the overall volume of them as a group a touch.
What is the easiest way to achieve this in Media Composer? In FCP7 I would probably have just nested them and adjusted the level of the nest accordingly. I am not familiar with "nests" existing in Avid (though fully expect I could be totally wrong on that), so what would an alternative method be?
Thanks in Advance,
Adam
Ricky Barrow
Re: Alternative to "nested" audio
on Apr 9, 2014 at 7:15:01 pm
Audio Mix tool - you can boost entire channel using in/out marks and the hamburger menu, you can gang channels as well for functions.
Ricky
Ricky Barrow
on Apr 9, 2014 at 7:15:42 pm
There is also in MC 7 a "Master fader" for control over the entire timeline.
Ricky
John Pale
on Apr 10, 2014 at 5:52:55 pm
If it's just a section, select the necessary tracks, set and in and out...then at the top of the mix tool, in the hamburger menu, select Adjust Pan/Vols In/Out. You can raise or lower then entire section a desired amount.
Adam White
on Apr 10, 2014 at 7:23:35 pm
Thanks both. Master Fader worked great this time around.
