mus.iD AMA plug-in now available!
Michael Phillips
on Apr 9, 2014 at 4:26:21 pm
If you've ever wanted to get the metadata from your MP3/M4A files from an iTunes or similar library into Media Composer, then the mus.iD plug-in is the answer.
I developed this with a friend of mine to have more information available to me while editing, such as BPM (Tempo), lyrics, and other tags such as genre etc, to be able to search on directly from within Media Composer.
And once edited into a sequence, a simple drag and drop of the AAF file onto the mus.iD reporting application will generate an Excel-ready file cue sheet with IN-OUT and duration of all the times it was used.
Get more information (and a demo video) here:
© 2018 All Rights Reserved
