No audio output when footage played in left/player window
mark wagner
on Apr 5, 2014 at 8:45:16 pm
hi
i am using Mediacomposer 6.5.3 running on OSX 10.7.5 with video and audio being output via a Bluefish Epoch card.
when loading a clip into the left player window i can´t hear any audio. as soon as it is edited into the timeline i can hear the audio.
any ideas?
tried checking all setting but no luck yet : /
Mark Wagner
Colorado | Berlin
John Pale
Re: No audio output when footage played in left/player window
on Apr 5, 2014 at 8:59:43 pm
Set your audio output to stereo instead of direct out, unless you are configured to monitor more than 2 channels.
mark wagner
on Apr 5, 2014 at 9:51:30 pm
tried that already but wasn´t solving the issue.
Mark Wagner
Colorado | Berlin
John Pale
on Apr 6, 2014 at 2:33:51 pm
Not familiar with the Bluefish card, but I'd start looking there. Does it have a control panel like the AJA or Blaxkmagic cards do?
mark wagner
on Apr 7, 2014 at 8:39:56 am
so checked again and the problem only occurs when i import music from mp3 source.
it just won´t play the audio (though the internal meter is showing signal) in the source window when the bluefish hardware is enabled.
any other ideas?
Mark Wagner
Colorado | Berlin
John Pale
on Apr 8, 2014 at 12:52:39 am
Try checking to make sure your import settings are converting the sample rate to your project setting (probably 48k).
Many mp3 files are 44.1.
