6.5.4 no audio after playback
James Reyes
on Mar 19, 2014 at 12:25:04 am
Hey Everyone,
I have two systems at the moment sharing media off a unity. One is mac and the other is PC. Everything is running fine but for some reason, the PC has an issue.
Whenever you load an audio clip into the source monitor it will play fine but as soon as you stop it or scrub to a different spot, no audio after that. The levels disappear as well.
I am using a decklink for both systems but the PC seems to be the one having the issue.
HP Z420 Workstation
xeon cpu E5-1650 V2 @ 3.50 GHz
32gb of ram
windows 7 professional 64 bit.
Any advice or help would be much appreciated. Thanks,
Glenn Sakatch
Re: 6.5.4 no audio after playback
on Mar 20, 2014 at 1:50:23 pm
I actually had a similar problem on my mac system a few weeks ago. running 7.03 (i think it was 03)
I could work fine for a while and then i lost my audio. a relaunch would fix the problem for a while. Eventually i just uninstalled and reinstalled the software. The reloaded version is working fine.
Glenn
James Reyes
on Mar 20, 2014 at 2:21:01 pm
I figured out the problem. Desktop player 10 was causing the issues so I installed 9.7. After that, audio playback was fine. Thanks for the advice!
