C300 avid workflow
emir jelassi
C300 avid workflow
on Feb 28, 2014 at 12:04:51 pm
salut a tout le monde;je vais débuter un montage sur avid media composer 6.5.2,j'ai des rushes tourné en 720p en slow motion et des rushes en 1080 en vitesse normale ,le tout avec la canon c300,au début je veux savoir comment mixer les deux résolutions sur un méme projet,sinon j'ai essayé sur avid de rendre les rushes tourné en slow motion en vitesse normale en appliquant timewarp 200 pour cent,et la j ai mes rushes qui sont en accélére et pas en vitesse normale,aidez moi svp et merci
Michael Phillips
Re: C300 avid workflow
on Feb 28, 2014 at 8:48:52 pm
You will need to define what your project frame rate and rsoltion will be to start with. Let's say 1080p/23.976. Any other frame rate and resolution will then be scaled or frame rate matched to work in that project type. A 720p/59.94 clip in that project type will be:
1. Scaled to 1920 x 1080 automatically
2. Frame Rate Mix and Match will automatically apply a motion adapter with the deffault always being maintain original duration. So a 1 minute clip at 59.94fps will still be a 1 minute clip when opened in the 23.976 project. As you remarked, you can cut the 59.94 clip into a sequence and then change the motion adaptor to be 100% (at 23.976) resulting in a 2.5x slomo from the 59,94fps material. Use that as a new source.
It would be great and long overdue that Avid add frame for frame as an option via AMA or not within project types.
© 2018 All Rights Reserved
