Cycle through clips loaded into Source Monitor
Shin Peng
on Feb 21, 2014 at 12:16:20 am
Hello all
Is there a KEYBOARD shortcut to cycle through the clips that are loaded in the source monitor?
(NOT the pulldown menu)
Thank you
Shane Ross
Re: Cycle through clips loaded into Source Monitor
on Feb 21, 2014 at 12:57:02 am
You can only have one clip loaded in the source monitor at a time. It does have a HISTORY of what you loaded before. No way to cycle through those via the keyboard that I know of...
Shane
Little Frog Post
Michael Phillips
on Feb 21, 2014 at 2:25:30 am
You can select clips in the bin and in the hamburger menu for that bin select "loop play" (or something like that, not in front of system). That will play each clip form IN-OUT and you can TAB to next, or SHIFT-TAB to reverse.
Also, you can just open any text file with with FILE/NEW SCRIPT and drag some clips on it and do the same thing.
Michael
