Media Composer 7. Consolidation. Foreign compression type Error
Elijah Smart
on Feb 7, 2014 at 4:29:13 am
Hi everyone.
I get the following error when I try to consolidate AVCHD clips in order to edit the sound in pro tools.
Some of the items selected for consolidate contained foreign compression types, which could not be consolidated. See the console for details.To consolidate these clips, please transcode them to a native compression type first.
Console output.
[ Plugin Name = AVCHD MSP Plug-In Avid Technology, Inc. Version = 1.3 ] processed F:\263\MEDIA\2221\PRIVATE\AVCHD\BDMV\STREAM\00000.MTS DIDDescriptor::GetAAFProperties() - Unable to map AAF Compression to MC Compression. DIDDescriptor::GetAAFProperties() - Unable to map AAF Compression to MC Compression. MSMRescan() took: 0.502000s The clip 00000 was skipped during the Consolidate operation because it is of a foreign compression type.
Is there anyway to get around this? E.g. a plugin or codec? Or do I have to transcode the audio first?
Pat Horridge
Re: Media Composer 7. Consolidation. Foreign compression type Error
on Feb 7, 2014 at 9:14:29 am
If going to Protools I'd Transcode first to be safe.
Make sure you have just the audio bed. Then transcode and select the audio options. Normally 16 bit, 48Khz WAV and transcode. Make sure you set long handles (I normally give 100 frames)
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Elijah Smart
on Feb 10, 2014 at 5:13:53 am
Ok. Thanks for that Pat.
