Composer Window Timecode Display Size
Scott Cole
on Jan 28, 2014 at 7:01:26 pm
While I'm using Media Composer 5.5, I'm sure it pertains to all versions. Somehow I changed the timecode display above the source and record monitors so that it is no longer a bolded font. Using the "Edit" | "Set Font" commands does not effect this text. Does anyone know how to change this display? My aging eyes just aren't dealing with this tiny display. Thanks
M. Scott Cole
Senior Post Production Editor
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
Richard Sanchez
Re: Composer Window Timecode Display Size
on Jan 28, 2014 at 7:08:01 pm
Granted, I'm on version 7 but set font adjusts that font size on my end. It's contextual, so you need to click the composer window first so that it's the active window.
UPDATE: Font size changes, not the actual font. Nevermind.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Scott Cole
on Jan 28, 2014 at 7:17:51 pm
Richard,
You would think that would be the case, but at least in V5.5 and lower, it isn't. I can change the size and fonts of the sequence or source names, but not the timecode displays or center duration. Very frustrating, as I can't find the setting for it. And I can see what I had on another system, which is the same font but bolded.
M. Scott Cole
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
Bill Ravens
on Jan 28, 2014 at 7:29:57 pm
As I recall, the settings are tied to font and size for another parameter, perhaps the Bin font/size. Trial and error should pinpoint it.
Scott Cole
on Jan 29, 2014 at 6:31:15 pm
After spending the worst part of an afternoon trying everything, including retrying the things suggested here and re-starting both MC and windows to no avail, I came in this morning, re-started per normal, and the displays in question were bolded again. Go figure.
M. Scott Cole
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
John Pale
on Feb 14, 2014 at 1:53:47 pm
Not sure if you are on Mac or Windows, Scott, but I think on windows, you can get some strange behavior if your system font mapping gets messed up.
Scott Cole
on Feb 15, 2014 at 3:08:32 pm
FYI, Windows. Problem went away on its own.
M. Scott Cole
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
