Avid Crashes during long export
Kyle Hinton
on Jan 27, 2014 at 4:10:02 pm
I am exporting an 67 minute video in avid at 1080i 60 and every time I try exporting it, it get about an hour in and then crashes.
H.264 Best compression and Linear PCM 48.000
how can i fix this?
I'm not giving a robot my name
Richard Sanchez
Re: Avid Crashes during long export
on Jan 27, 2014 at 4:24:52 pm
That can be cause by a corrupted render. Mark and in and out splitting the sequence in half. Try to export. See if it crashes. If not, move to the second half. Continue this process to zero in on the offending section. Once you find the bad render, mark an in and out point around it and go to Clip (I think) and select "Clear Render Effects In to Out".
However, since you didn't list your spec, just for good measure, are you using DNxHD media? Or is there a ton of AMA footage? Also, you could try exporting a "Same as Source" quicktime and compressing it using Sorenson Squeeze or Compressor.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Michael Phillips
on Jan 27, 2014 at 5:59:58 pm
You are usually better off as Richard states to export a QT reference and encode to streaming codes in a third party app - even the free MPEGStreamclip works great.
Michael
