Avid DVD by Sonic link subtitles to menu
Sandy Cummings
on Jan 4, 2014 at 3:29:18 pm
I'm authoring a DVD with two subtitle languages and want to make the subtitles selectable from the menu. There are 8 movies on the DVD with options to play individually or play all. I can't find anything in the documentation to do this,
Guidance is appreciated!
Pat Horridge
Re: Avid DVD by Sonic link subtitles to menu
on Jan 5, 2014 at 9:21:41 am
Each menu item you add allows you to link to a title and specify the audio track and subtitle track to use.
So you can create multiple menu options for the same content.
But that's an ugle approach. I'd use a more featured authoring solution like Scenarist ( which we use) and use GPRMs to store a users subtile (or clean) choice and use that to enable or not the required subtitle. That way you have a seperate subtitle choice menu.
Using the Avid DVD you'd most likely create the subtitle choice menu first and from that step to one of 3 identical menuz to play the 8 titles hardcoded to enable the required subtitle or clean. Don't forget back buttons.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Sandy Cummings
on Jan 10, 2014 at 10:33:39 pm
Pat,
Thanks so much for your post -- it's very helpful. I think I'm on the right path now!
Sandy
