optimizing Mac for Media Composer 7 trial
Steven Austin
on Dec 19, 2013 at 12:51:05 am
Hello. Current FCP7 user. I want to learn Avid Media Composer 7, via the 30 day trial. My system is 32 bit and I need to change it (somehow). Is my current setup OK for MC7? Will it still run FCP7 if I switch to 64 bit? Running Snow Leopard. Raptor 10,000 RPM main drive. Thank you.
Model Identifier: MacPro1,1
Processor Name: Dual-Core Intel Xeon
Processor Speed: 2.66 GHz
Number Of Processors: 2
Total Number Of Cores: 4
L2 Cache (per processor): 4 MB
Memory: 9 GB
Bus Speed: 1.33 GHz
Boot ROM Version: MP11.005D.B00
SMC Version (system): 1.7f10
Shane Ross
Re: optimizing Mac for Media Composer 7 trial
on Dec 19, 2013 at 5:47:12 pm
That old MacPro...1,1...is 32 bit only. It cannot run at 64 bit. It might run the 64 bit OS...but at 32 bit. Yes, Avid will work, but it won't be as fast as it would be running at 64 bit...obviously.
Shane
Little Frog Post
Steven Austin
on Jan 10, 2014 at 5:44:23 pm
Thanks. Until I can afford the new Mac Pro (OS Marevick isn\'t even compatible with AVid MC7 yet) I thought I might get a used 62 bit iMac or a Hackintosh. Does that sound like a reasonable plan? Rather than spend a minimum of 4k I could run Avid for about a year at half the cost...
Graham Tees
on Jan 10, 2014 at 8:50:33 pm
Avid released Ver 7.0.3 a couple of weeks ago with Mavericks support. See here http://community.avid.com/forums/p/124598/714979.aspx#714979
