Extracting multiple audio files.
Robin Lewis
on Dec 18, 2013 at 8:55:03 am
I have a large Avid Media composer bin of SFX that I have been using for the last year but now I want the files as just normal .wav sound files so I can use them in FCP and Adobe. Is there any way I can select all the audio media in a bin and export it as .wav (or another file type) retaining the name it has in avid?
Thanks for the advise
Robin
Michael Phillips
Re: Extracting multiple audio files.
on Dec 19, 2013 at 12:36:23 am
From the bin, select all the masterclips you want to export. Do a file export and select audio WAV as your format, and you're good to go. Each masterclip will be a new WAV clip with the same name as seen in the bin.
Michael
