what project setting should I use for 1920x1440 footage?
Tom Smith
on Dec 12, 2013 at 7:40:19 am
There's no setting for this, closest is of course 1080 but it's a 4:3 ratio which would fit the 640x480 project setting.
I plan on AMA linking and transcoding of course. Currently it is in prores 422. it is VHS video captures from 480 up into 1440. Final deliverable; I'm sure the director would want it in HD so he could toss it on a Blu Ray. So yes it would be 4:3 frame in an HD raster size. The audience would be seeing pillar boxes.
Shane Ross
Re: what project setting should I use for 1920x1440 footage?
on Dec 12, 2013 at 8:28:45 am
You mean 1440x1080..4:3.
Use a 1920x1080 setting that matches the frame rate...29.97 most likely.
Shane
Little Frog Post
Tom Smith
on Dec 12, 2013 at 8:34:09 am
Nope its 1920x1440, as shown in the pic (File info out of Premiere) http://i.imgur.com/KHcWGUc.png
Shane Ross
on Dec 12, 2013 at 8:36:48 am
How did you end up with that? You did something wrong. 4:3 SD blown up to HD, and to retain the 4:3 dimensions, should be 1440x1080.
The closest setting Avid has to what you want is 1920x1080. Not sure how your footage will import that.
Shane
Little Frog Post
Tom Smith
on Dec 12, 2013 at 8:53:33 am
Well i didnt do anything, I was given the footage by the director. He captured it off VHS.
I mean sure you can get it to play back properly in Avid and not look distorted in the composer window, but exporting... Well anything I tried ends up squishing the footage and pillarboxing.
ANY tips you might have for me at this point I would love. I am more worried about the exporting portion of course.
Tom Smith
on Dec 12, 2013 at 9:05:58 am
Just FYI, I made a 1080 sequence and 1920x1080 raster and exported same as source and it exported correctly. Pillarboxes on the side. I am not sure why the director did this, but its something the actual editor will have to deal if it's a problem after the director makes his rough cut. He nor I have time to deal with it at this point. If it means re encoding and then relinking then so be it.
Michael Phillips
on Dec 12, 2013 at 1:56:45 pm
If the footage aspect ratio is truly 4:3, then it will have pillarbox. If the content is anamorphic, then a stretch will do the trick. In cases where the footage is 4:3 - usually you want to keep all the pixels when doing an HD uprez (or transfer from film) and then deal with it as pillarbox, or a pan & scan or tilt & scan in this scenario if you want to create full 16:9. If not, then it is pillarbox. MC only knows 16:9 in HD so if you want a 4:3 file at the end of the process, export 16:9 pillarbox and do a crop in an encoding application.
Michael
Tom Smith
on Dec 13, 2013 at 3:32:41 am
thanks for tips :)
