Sapphire DeFlicker in Symphony?
Ernest Savage
on Nov 15, 2013 at 11:37:33 pm
Any tips in making Sapphire DeFlicker actually affect a clip? If tried setting the point, and moving the square, but I get only minor results.
John Pale
Re: Sapphire DeFlicker in Symphony?
on Nov 16, 2013 at 1:34:54 am
I've had much better results with the BCC filter that does the same thing. You got it free with symphony.
Ernest Savage
on Nov 16, 2013 at 6:03:18 am
Some how this symphony doesn't have BCC. I found a work around. I simply removed the frames with the higher luminance causing the flicker, and timewarped the clip to match the motion and timing of the original. Looks good. Thanks for the BCC tip. I'll try when I can BCC again.
John Pale
on Nov 16, 2013 at 2:32:58 pm
You are entitled to the BCC suite (Boris continuum). It's a separate install. You can download it from Avid's website.
Glad it worked out.
Note that both the sapphire and BCC flicker fix filters have several modes to try to remove the flicker, so you need to play with it a bit and use their help/manuals, as the controls are not that obvious. I've always had better luck with BCC than Sapphire for this, though the Sapphire filters are excellent in general, and mostly superior to the BCC.
Ernest Savage
on Nov 19, 2013 at 8:52:16 pm
