Can't apply effects
Daniel Schultz
Can't apply effects
on Nov 1, 2013 at 12:44:40 pm
Okay, I thought I had done this properly.
I checked the footage (HDV 29.97) and set my project up to what I thought were the same parameters before importing the footage. I wasn't able to AMA link (comes from a somewhat outdated Sony Z5 camera), so I just dragged the clips into a bin and allowed AVID to transcode everything to MXF.
Now I'm editing in the timeline and a number of functions seem greyed out or otherwise unavailable, like speeding up clips, and making freeze frame.
Any thoughts on what I might be doing wrong?
Many thanks,
Dan Schultz
John Pale
Re: Can't apply effects
on Nov 1, 2013 at 12:50:52 pm
If your footage does not match your project frame rate, your clips already have a speed effect on them (note the green dot) called a motion Adapter. If you want to adjust the speed, you will have to do it in a sequence by opening the motion effect editor,
If you want a freeze, find the frame you want and change the speed to zero.
