the edit rate of the clip (50.000000) does not match the project edit rate site (25.000000)
Paul Donahue
on Oct 24, 2013 at 7:52:18 pm
I shot footage on a Canon XF 305 camera at 50 Mbps 1280x720, exported the MXF clips from the Canon XF Utility, and tried to bring them into an Avid MC 6.5.3 project that was set at 720p/25 and received the above message
the edit rate of the clip (50.000000) does not match the project edit rate site (25.000000).
Is there a way to still bring these clips into the project? Avid MC does not have a 720p/50 project setting and the XF 305 does not have a 1280x720 25Mbps setting, but there must be a way to bring this type of clips into an Avid project.
Thanks in advance,
Paul
Paul Donahue
Media Eye
http://www.mediaeyemedia.com
Richard Sanchez
Re: the edit rate of the clip (50.000000) does not match the project edit rate site (25.000000)
on Oct 24, 2013 at 7:56:07 pm
I'm pretty sure MC does have a 720/50 project option. Try creating a new project.
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Paul Donahue
on Oct 24, 2013 at 8:11:50 pm
Unfortunately, there is not 720/50 project option. I don't really understand why.
Paul
Paul Donahue
Media Eye
Michael Phillips
on Oct 24, 2013 at 8:30:47 pm
Here is what I see when creating a new project, and 720p/50 is definitely there. But it is unfortunate that Media Composer still doesn't have a 1080p/50 and 1080p/59.94 project type. For now you need to choose between resolution and frame rate. If you want all 50 progressive frames to edit on, then choose 720 (reducing resolution) or choose 1080i/50 where each frame becomes a field reducing vertical resolution by half and editing on ever other "frame".
Michael
Richard Sanchez
on Oct 24, 2013 at 8:32:48 pm
I'm using MC 6.5.2.
Richard Sanchez
Los Angeles, CA
Paul Donahue
on Oct 24, 2013 at 8:40:42 pm
i've now opened up a new project and i can choose 720/50. Thanks!
Paul
Paul Donahue
Media Eye
Clayton Lonie
on Oct 25, 2013 at 7:21:12 am
Open clips in 720/50... Then create your 25p project.
Then open the 720/50 bin in the 25p project ... Avid will
Then handle all conversions for you.
Avid Media Composer Expert User. (Modist, I know!!!)
Paul Donahue
on Oct 25, 2013 at 11:26:25 am
Thanks for this advice. That explains perfectly what I would like to do.
Sincerely,
Paul
Paul Donahue
Media Eye
