XDCAM HD 50Mbits not linking to AMA Volume
barrett neimeth
on Oct 20, 2013 at 6:35:20 pm
Hey All,
Having some issues with footage shot with the C300.
Linking to AMA volume half the card appears, the codecs that show up are-
CANON XF MPEG-2 422 50Mbits
MPEG2-4:2:2P@HL (HD720p)
The clips that won't show up, when I link to AMA Files they come in as
XDCAM HD 50Mbits
Why won't is let me link to volume with these?
I think I have the correct plugin.
xpmw-2-0-3-8-9l
The folder structure of the card seems to be intact.
My system is Windows 7 64bit
Avid 6.0.3.3
Thank you,
Barrett
Michael Phillips
Re: XDCAM HD 50Mbits not linking to AMA Volume
on Oct 20, 2013 at 7:49:39 pm
Make sure you download ALL the Canon plug-ins and not just the one you think you need (300 and 305). I have heard of this fixing some issues.
Also what frame rate?
Michael
barrett neimeth
on Oct 20, 2013 at 10:13:40 pm
the footage is 23.98, will try downloading the other plugins and let you know what happens. thanks for the response. -B
barrett neimeth
on Oct 21, 2013 at 3:38:14 am
I went to the pages for XF105, XF300, XF305 and the plugins are the same on every page, same as the one I have.
http://www.usa.canon.com/cusa/support/professional/professional_cameras/hig...
http://www.usa.canon.com/cusa/professional/products/professional_cameras/hd...
Any other ideas?
-B
Shane Ross
on Oct 21, 2013 at 6:06:53 am
Not just those...every AMA plugin. The ones for AVCHD, P2...etc. I'm not sure what other one helps, but when I was in this situation, only loading all of them seemed to make this work.
Shane
Little Frog Post
John Pale
on Oct 22, 2013 at 12:46:22 am
Have you tried manually selecting the correct AMA plugin to use in the link dialog as opposed to leaving it at the default setting of auto?
It may be guessing wrong when set to auto on some clips for whatever reason.
Michael Phillips
on Oct 22, 2013 at 12:55:30 am
Good point. I have found "auto" to really only work on files that can be opened via QuickTime. Even unique files like .r3d have had trouble with "auto".
Michael
