export too dark
Pieter Smet
export too dark
on Oct 16, 2013 at 11:58:51 pm
Hello,
I know a lot of people have had this problem but I can't figure out what I am doing wrong.
When I export my sequence in DNxHD (rec709) the result is as it was in Avid, but then when I convert it to h.264 (with compressor or mpeg streamclip) the result is that the blacks drop. So the image is too dark.
When I export in RGB the result is the dark immediately.
My workflow:
• open AMA volume (prores and sony f5 material)
• transcode to DNxHD 36
• edit
• export (DNxHD)
• make conversions.
QT ref hasn't been a solution so far.
Really don't know what to do now, so all help is more then welcome.
Thnx,
P.
Job ter Burg
Re: export too dark
on Oct 17, 2013 at 9:28:01 am
That's the infamous H264 gamma issue in QT. Better export QT Ref or Same As Source, then transcode to x264 or Main Concept H264 in Sorensen Squeeze (you got a Squeeze serial with your MC).
