Relinking
Kira Light
Relinking
on Oct 16, 2013 at 2:03:17 pm
Sorry if this is a really obvious question but... if you've transcoded some files into avid via ama, cut something (teeny tiny - about 1 minute) but then realise you've transcoded to the wrong format, what's the best way to relink your sequence to the correct media once you've re-transcoded it?
Sean Smith
Re: Relinking
on Oct 17, 2013 at 3:51:02 am
Decompose the sequence (or sub-sequence if it's just part of it), then relink the empty decomposed sequence. In the relink options, you'll be able to select a specific format. I tend to get better success with relinking when I've decomposed first.
Kira Light
Re: Relinking
on Nov 6, 2013 at 8:51:26 am
Thanks for this... :D
