What does 'fast export' actually do?
Jimmy See
on Oct 7, 2013 at 1:53:27 am
Just curious what the difference is between export and 'fast' export when making QTs from Avid. Is fast export just a combination of settings one could set themselves in a custom preset or is it actually something different. I notice it doesn't seem to be necessary to render a BITC layer when using this preset and that it takes roughly real time which is pretty good. Is it anything special, or just a useful combination of settings?
Daniel Frome
Re: What does 'fast export' actually do?
on Oct 7, 2013 at 12:32:22 pm
Edit: misread --
Fast export is basically Avid exporting out the same format as the project settings. It can re-use rendered elements, etc, to build your quicktime file.
Jimmy See
on Oct 8, 2013 at 8:01:18 am
what's the difference between this and same as source?
