Any Avid Color Correction effect preset to mimic an LUT?
Francis Zuccarello
on Sep 25, 2013 at 4:54:11 pm
Friends,
Starting very soon I’ll be cutting a project in MC 6.5.2 that is shot with an Arri Alexa to ProRes 2K. I know I cannot transcode the material with an LUT, but I’ve already done a test capture in which I’ve applied an Avid Color Correction effect to give the footage rich and full saturation with healthy contrast.
Do any users have one or more Avid Color Correction presets or recipes she or he can share with me that have worked well to make Arri Alexa footage appear as if the proper LUT has been applied?
Regards,
Mr. Francis Zuccarello
System: MacBook Pro, 17-inch, Early 2008
Processor: 2.5 GHz Intel Core 2 Duo
Memory: 4 GB 667 MHz DDR2 SDRAM
Graphics: NVIDIA GeForce 8600M GT 512 MB
Michael Phillips
Re: Any Avid Color Correction effect preset to mimic an LUT?
on Sep 25, 2013 at 11:20:33 pm
Since you mention "transcode" why not make native MXF/DNxHD using Resolve Lite that is free? You can apply a LUT there and you're good to go. See:
http://www.avid.com/static/resources/documents/whitepapers/digital_camera/d...
For overall information.
Or consider moving up to v7 which has support for source side 1D and 3D LUTs as well as ASC CDL.
Michael
Francis Zuccarello
on Sep 26, 2013 at 12:07:14 am
Thank you for your suggestions, which I will take under consideration; however, I would like to keep my question on the table.
Michael Phillips
on Sep 26, 2013 at 12:53:20 pm
You can only "approximate" in Media Composer UI as it only allows for 16 points on each of the RGB curves, while a 3D LUT has many more points to create the exact curve for the sensor being used. You are close in your efforts - most people so a basic S curve on the mater RGB and add some contrast. But while you can get close, using sequences as source for editorial is a bit of a pain which is why applying to either the dailies or in v7 as a source side effect makes or a more pleasing experience. Doing it in v7 allows you to add, remove, and change as needed.
Here is what a LogC to Rec.709 3D LUT looks like values wise as generated by Arri on their LUT generator site:
# Alexa conversion LUT, logc2video, itu709. Legal in/legal out.
# created by alexalutconv (2.06)
LUT_3D_SIZE 32
0.062561 0.062561 0.062561
0.072517 0.062561 0.062633
0.098445 0.062561 0.062821
0.130131 0.062561 0.063070
0.165067 0.062561 0.063459
0.204272 0.062561 0.064076
0.249645 0.062561 0.065061
0.307893 0.062561 0.066817
0.376486 0.062561 0.069698
0.449823 0.062561 0.073889
0.523186 0.062561 0.079376
0.595931 0.062561 0.086236
0.667749 0.062561 0.094529
0.738213 0.062561 0.104254
0.806874 0.062561 0.115221
0.873276 0.062561 0.126114
0.918866 0.062561 0.135624
0.918866 0.062561 0.142958
0.918866 0.062561 0.148410
0.918866 0.062561 0.152276
0.918866 0.062561 0.154850
0.918866 0.062561 0.156426
0.918866 0.062561 0.157298
0.918866 0.062561 0.157656
0.062561 0.071162 0.062561
0.069827 0.070935 0.062561
0.095755 0.070346 0.062561
0.127985 0.069568 0.062561
0.163577 0.068350 0.062641
0.203205 0.066420 0.063258
0.248869 0.063336 0.064243
0.307339 0.062561 0.065999
0.376088 0.062561 0.068880
0.449525 0.062561 0.073070
0.522955 0.062561 0.078557
0.595745 0.062561 0.085418
0.667595 0.062561 0.093711
0.738082 0.062561 0.103436
0.806762 0.062561 0.114446
0.873178 0.062561 0.125435
0.918866 0.062561 0.135016
0.918866 0.062561 0.142397
0.918866 0.062561 0.147880
0.918866 0.062561 0.151766
0.918866 0.062561 0.154353
0.918866 0.062561 0.155936
0.918866 0.062561 0.156813
0.918866 0.062561 0.157172
0.062561 0.093561 0.062561
0.062821 0.093335 0.062561
0.088750 0.092746 0.062561
0.122128 0.091968 0.062561
0.159596 0.090748 0.062561
0.200384 0.088819 0.062561
0.246830 0.085735 0.062561
0.305890 0.080238 0.063869
0.375046 0.071221 0.066749
0.448749 0.062561 0.070940
0.522350 0.062561 0.076427
0.595259 0.062561 0.083287
0.667193 0.062561 0.091581
0.737743 0.062561 0.101306
0.806469 0.062561 0.112389
0.872922 0.062561 0.123643
0.918866 0.062561 0.133413
0.918866 0.062561 0.140918
0.918866 0.062561 0.146484
0.918866 0.062561 0.150425
0.918866 0.062561 0.153046
0.918866 0.062561 0.154650
0.918866 0.062561 0.155537
0.918866 0.062561 0.155901
0.062561 0.122257 0.062561
0.062561 0.122062 0.062561
0.079496 0.121550 0.062561
0.113690 0.120868 0.062561
0.154093 0.119789 0.062561
0.196558 0.118051 0.062561
0.244094 0.115193 0.062561
0.303959 0.109828 0.062561
0.373662 0.100811 0.063935
0.447720 0.087694 0.068126
0.521550 0.070518 0.073612
0.594615 0.062561 0.080473
0.666661 0.062561 0.088765
0.737294 0.062561 0.098492
0.806083 0.062561 0.109593
0.872583 0.062561 0.121215
0.918866 0.062561 0.131250
0.918866 0.062561 0.138928
0.918866 0.062561 0.144610
0.918866 0.062561 0.148625
0.918866 0.062561 0.151294
0.918866 0.062561 0.152926
0.918866 0.062561 0.153828
0.918866 0.062561 0.154198
0.062561 0.155366 0.062561
0.062561 0.155229 0.062561
0.064992 0.154873 0.062561
0.099245 0.154400 0.062561
0.144812 0.153655 0.062561
0.190318 0.152464 0.062561
0.239707 0.150531 0.062561
0.300891 0.146987 0.062561
0.371477 0.140878 0.062561
0.446099 0.131206 0.063715
0.520292 0.116659 0.069202
0.593604 0.095418 0.076062
0.665827 0.069460 0.084355
0.736589 0.062561 0.094080
0.805476 0.062561 0.105182
0.872052 0.062561 0.117258
0.918866 0.062561 0.127748
0.918866 0.062561 0.135721
0.918866 0.062561 0.141595
0.918866 0.062561 0.145736
0.918866 0.062561 0.148483
0.918866 0.062561 0.150161
0.918866 0.062561 0.151089
0.918866 0.062561 0.151469
0.062561 0.192523 0.062561
0.062561 0.192424 0.062561
0.062561 0.192169 0.062561
0.076298 0.191830 0.062561
0.127963 0.191297 0.062561
0.179738 0.190449 0.062561
0.232491 0.189082 0.062561
0.295932 0.186606 0.062561
0.367975 0.182430 0.062561
0.443514 0.176077 0.062561
0.518292 0.167182 0.062561
0.591999 0.154919 0.069084
0.664503 0.137778 0.077377
0.735472 0.112368 0.087102
0.804515 0.077635 0.098203
0.871212 0.062561 0.110564
0.918866 0.062561 0.121898
0.918866 0.062561 0.130401
0.918866 0.062561 0.136617
0.918866 0.062561 0.140979
0.918866 0.062561 0.143864
0.918866 0.062561 0.145624
0.918866 0.062561 0.146595
0.918866 0.062561 0.146993
0.062561 0.235523 0.062561
0.062561 0.235452 0.062561
0.062561 0.235266 0.062561
0.062561 0.235020 0.062561
0.093296 0.234633 0.062561
0.160485 0.234019 0.062561
0.220159 0.233032 0.062561
0.287714 0.231256 0.062561
0.362263 0.228296 0.062561
0.439330 0.223879 0.062561
0.515067 0.217877 0.062561
0.589419 0.209986 0.062561
0.662377 0.199778 0.066220
0.733679 0.186657 0.075946
0.802974 0.169672 0.087047
0.869865 0.147012 0.099408
0.918866 0.117805 0.111575
0.918866 0.085886 0.121153
0.918866 0.062561 0.128043
0.918866 0.062561 0.132830
0.918866 0.062561 0.135977
0.918866 0.062561 0.137890
0.918866 0.062561 0.138943
0.918866 0.062561 0.139375
0.062561 0.290726 0.062561
0.062561 0.290675 0.062561
0.062561 0.290542 0.062561
0.062561 0.290367 0.062561
0.062561 0.290091 0.062561
0.112811 0.289654 0.062561
0.194979 0.288954 0.062561
0.272048 0.287698 0.062561
0.351699 0.285619 0.062561
0.431705 0.282550 0.062561
0.509234 0.278449 0.062561
0.584770 0.273181 0.062561
0.658559 0.266586 0.062561
0.730466 0.258504 0.062561
0.800215 0.248755 0.067162
0.867454 0.237129 0.079523
0.918866 0.224721 0.091695
0.918866 0.213300 0.101999
0.918866 0.203475 0.110195
0.918866 0.195657 0.116097
0.918866 0.189984 0.119915
0.918866 0.186301 0.122212
0.918866 0.184187 0.123471
0.918866 0.183304 0.123985
0.062561 0.355734 0.062561
0.062561 0.355697 0.062561
0.062561 0.355601 0.062561
0.062561 0.355475 0.062561
0.062561 0.355276 0.062561
0.062561 0.354962 0.062561
0.136711 0.354459 0.062561
0.242665 0.353558 0.062561
0.333155 0.352073 0.062561
0.418694 0.349894 0.062561
0.499419 0.347007 0.062561
0.577010 0.343342 0.062561
0.652214 0.338825 0.062561
0.725143 0.333399 0.062561
0.795654 0.327025 0.062561
0.863477 0.319682 0.062561
0.918866 0.312173 0.062561
0.918866 0.305580 0.069379
0.918866 0.300167 0.077576
0.918866 0.296037 0.083671
0.918866 0.293142 0.087861
0.918866 0.291309 0.090480
0.918866 0.290275 0.091947
0.918866 0.289846 0.092552
0.062561 0.425237 0.062561
0.062561 0.425210 0.062561
0.062561 0.425138 0.062561
0.062561 0.425044 0.062561
0.062561 0.424896 0.062561
0.062561 0.424661 0.062561
0.062561 0.424286 0.062561
0.185591 0.423616 0.062561
0.302736 0.422513 0.062561
0.398487 0.420900 0.062561
0.484543 0.418772 0.062561
0.565401 0.416087 0.062561
0.642796 0.412802 0.062561
0.717281 0.408895 0.062561
0.788940 0.404357 0.062561
0.857635 0.399205 0.062561
0.917256 0.394023 0.062561
0.918866 0.389547 0.062561
0.918866 0.385925 0.062561
0.918866 0.383196 0.062561
0.918866 0.381301 0.062561
0.918866 0.380108 0.062561
0.918866 0.379438 0.062561
0.918866 0.379161 0.062561
0.062561 0.494765 0.062561
0.062561 0.494744 0.062561
0.062561 0.494688 0.062561
0.062561 0.494614 0.062561
0.062561 0.494500 0.062561
0.062561 0.494317 0.062561
0.062561 0.494025 0.062561
0.062561 0.493504 0.062561
0.253332 0.492648 0.062561
0.369178 0.491397 0.062561
0.463843 0.489751 0.062561
0.549573 0.487681 0.062561
0.630105 0.485159 0.062561
0.706763 0.482173 0.062561
0.780001 0.478727 0.062561
0.849883 0.474841 0.062561
0.910343 0.470962 0.062561
0.918866 0.467637 0.062561
0.918866 0.464964 0.062561
0.918866 0.462959 0.062561
0.918866 0.461573 0.062561
0.918866 0.460703 0.062561
0.918866 0.460215 0.062561
0.918866 0.460013 0.062561
0.062561 0.563708 0.062561
0.062561 0.563691 0.062561
0.062561 0.563646 0.062561
0.062561 0.563587 0.062561
0.062561 0.563494 0.062561
0.062561 0.563347 0.062561
0.062561 0.563113 0.062561
0.062561 0.562693 0.062561
0.152358 0.562004 0.062561
0.326115 0.561000 0.062561
0.435593 0.559680 0.062561
0.528648 0.558023 0.062561
0.613609 0.556009 0.062561
0.693230 0.553631 0.062561
0.768576 0.550896 0.062561
0.840019 0.547824 0.062561
0.901573 0.544770 0.062561
0.918866 0.542163 0.062561
0.918866 0.540075 0.062561
0.918866 0.538512 0.062561
0.918866 0.537434 0.062561
0.918866 0.536759 0.062561
0.918866 0.536379 0.062561
0.918866 0.536222 0.062561
0.062561 0.631772 0.062561
0.062561 0.631757 0.062561
0.062561 0.631720 0.062561
0.062561 0.631671 0.062561
0.062561 0.631594 0.062561
0.062561 0.631473 0.062561
0.062561 0.631279 0.062561
0.062561 0.630933 0.062561
0.062561 0.630364 0.062561
0.257021 0.629534 0.062561
0.396812 0.628446 0.062561
0.501362 0.627081 0.062561
0.592627 0.625424 0.062561
0.676259 0.623472 0.062561
0.754374 0.621231 0.062561
0.827830 0.618719 0.062561
0.890776 0.616230 0.062561
0.918866 0.614109 0.062561
0.918866 0.612413 0.062561
0.918866 0.611147 0.062561
0.918866 0.610274 0.062561
0.918866 0.609727 0.062561
0.918866 0.609420 0.062561
0.918866 0.609293 0.062561
0.062561 0.698552 0.062561
0.062561 0.698540 0.062561
0.062561 0.698508 0.062561
0.062561 0.698467 0.062561
0.062561 0.698402 0.062561
0.062561 0.698299 0.062561
0.062561 0.698135 0.062561
0.062561 0.697843 0.062561
0.062561 0.697363 0.062561
0.071233 0.696662 0.062561
0.341480 0.695744 0.062561
0.465849 0.694593 0.062561
0.566323 0.693198 0.062561
0.655399 0.691555 0.062561
0.737124 0.689671 0.062561
0.813138 0.687565 0.062561
0.877826 0.685479 0.062561
0.918866 0.683706 0.062561
0.918866 0.682290 0.062561
0.918866 0.681233 0.062561
0.918866 0.680505 0.062561
0.918866 0.680049 0.062561
0.918866 0.679794 0.062561
0.918866 0.679688 0.062561
0.062561 0.763624 0.062561
0.062561 0.763613 0.062561
0.062561 0.763586 0.062561
0.062561 0.763551 0.062561
0.062561 0.763495 0.062561
0.062561 0.763406 0.062561
0.062561 0.763265 0.062561
0.062561 0.763013 0.062561
0.062561 0.762600 0.062561
0.062561 0.761997 0.062561
0.251623 0.761207 0.062561
0.418896 0.760218 0.062561
0.533569 0.759019 0.062561
0.630143 0.757609 0.062561
0.716566 0.755993 0.062561
0.795801 0.754188 0.062561
0.862637 0.752404 0.062561
0.913071 0.750887 0.062561
0.918866 0.749678 0.062561
0.918866 0.748775 0.062561
0.918866 0.748154 0.062561
0.918866 0.747766 0.062561
0.918866 0.747548 0.062561
0.918866 0.747458 0.062561
0.062561 0.826554 0.062561
0.062561 0.826546 0.062561
0.062561 0.826522 0.062561
0.062561 0.826490 0.062561
0.062561 0.826442 0.062561
0.062561 0.826365 0.062561
0.062561 0.826241 0.062561
0.062561 0.826020 0.062561
0.062561 0.825658 0.062561
0.062561 0.825131 0.062561
0.062561 0.824441 0.062561
0.353614 0.823576 0.062561
0.492654 0.822528 0.062561
0.599871 0.821296 0.062561
0.692447 0.819886 0.062561
0.775720 0.818312 0.062561
0.845179 0.816757 0.062561
0.897246 0.815436 0.062561
0.918866 0.814383 0.062561
0.918866 0.813598 0.062561
0.918866 0.813058 0.062561
0.918866 0.812721 0.062561
0.918866 0.812531 0.062561
0.918866 0.812453 0.062561
0.062561 0.881504 0.062561
0.062561 0.881495 0.062561
0.062561 0.881474 0.062561
0.062561 0.881446 0.062561
0.062561 0.881403 0.062561
0.062561 0.881333 0.062561
0.062561 0.881222 0.062561
0.062561 0.881024 0.062561
0.062561 0.880699 0.062561
0.062561 0.880227 0.062561
0.062561 0.879607 0.062561
0.260475 0.878832 0.062561
0.445955 0.877893 0.062561
0.567338 0.876789 0.062561
0.667234 0.875527 0.062561
0.755053 0.874118 0.062561
0.827372 0.872727 0.062561
0.881188 0.871546 0.062561
0.918866 0.870604 0.062561
0.918866 0.869904 0.062561
0.918866 0.869421 0.062561
0.918866 0.869119 0.062561
0.918866 0.868950 0.062561
0.918866 0.868880 0.062561
0.062561 0.918866 0.062561
0.398942 0.918866 0.062561
0.537147 0.918866 0.062561
0.644572 0.918357 0.062561
0.736783 0.917057 0.062561
0.811777 0.915773 0.062561
0.867200 0.914685 0.062561
0.907363 0.913817 0.062561
0.918866 0.913171 0.062561
0.918866 0.912727 0.062561
0.918866 0.912449 0.062561
0.918866 0.912293 0.062561
0.918866 0.912229 0.062561
0.353743 0.918866 0.062561
0.510945 0.918866 0.062561
0.625546 0.918866 0.062561
0.721689 0.918866 0.062561
0.799003 0.918866 0.062561
0.855794 0.918866 0.062561
0.896809 0.918866 0.062561
0.918866 0.918866 0.062561
0.312761 0.918866 0.062561
0.489911 0.918866 0.062561
0.610744 0.918866 0.062561
0.710112 0.918866 0.062561
0.789275 0.918866 0.062561
0.847144 0.918866 0.062561
0.888823 0.918866 0.062561
0.917803 0.918866 0.062561
0.278553 0.918866 0.062561
0.474533 0.918866 0.062561
0.600209 0.918866 0.062561
0.701964 0.918866 0.062561
0.782469 0.918866 0.062561
0.841108 0.918866 0.062561
0.883261 0.918866 0.062561
0.912536 0.918866 0.062561
0.253192 0.918866 0.062561
0.464488 0.918866 0.062561
0.593464 0.918866 0.062561
0.696790 0.918866 0.062561
0.778164 0.918866 0.062561
0.837300 0.918866 0.062561
0.879755 0.918866 0.062561
0.909219 0.918866 0.062561
0.237015 0.918866 0.062561
0.458702 0.918866 0.062561
0.589631 0.918866 0.062561
0.693864 0.918866 0.062561
0.775735 0.918866 0.062561
0.835154 0.918866 0.062561
0.877782 0.918866 0.062561
0.907352 0.918866 0.062561
0.229801 0.918866 0.062561
0.456279 0.918866 0.062561
0.588038 0.918866 0.062561
0.692651 0.918866 0.062561
0.774730 0.918866 0.062561
0.834266 0.918866 0.062561
0.876965 0.918866 0.062561
0.906580 0.918866 0.062561
