Reconnect using AMA
Chris McElroy
Reconnect using AMA
on Sep 16, 2013 at 7:30:33 pm
I inherited a a project from a previous editor on Media Composer 6.5
He was in the habit of editing using AMA. I am unable to connect to the media, even though it is on a local drive. Any advice?
thanks
Khoren Mirzakhanian
Re: Reconnect using AMA
on Sep 18, 2013 at 6:48:05 pm
load the ama clips in a bin, either by "link to ama files" or "load ama volume"
then select your sequence and relink. should do the trick. also check to see if those clips that are offline, have tape names.
Sean Smith
on Oct 1, 2013 at 1:11:03 am
I think you might have to have the clips in the AMA bin selected when you relink too.
