Adobe Media Encoder won't accept Quicktime reference file
Joshua Menco
on Sep 5, 2013 at 12:39:50 pm
Hi Guys,
Having a weird problem here.
When I export a qt ref file from avid to my AME watch folder, just the .aiff shows up. The .mov doesn't open in AME. When I physically go to the watch folder I can see that the .mov HAS exported from avid and when I press space (I'm on Mac), the .mov plays just fine. However when I then drag it into the AME queue manually it tells me:
" File Import Error. The file /Volumes/etc. could not be imported. The source file appears to be corrupted. Please check that it is a valid file. "
A few things that I have done already to narrow the problem down:
-Tried to open the qt ref .mov file in mpegstreamclip (works just fine)
-Opened a another project with an identical sequence and exported the sequence (canon dslr imported at dnxhd 185 and synced with pluraleyes). This one worked just fine..
-ReInstalled Avid LE and PE codecs (just to be sure)
-Tried all the settings in the avid qt ref export dialogue box (avid codecs, flatten video, mixdown audio. None made a difference)
Please help me!! Going crazy here :)
Joshua Menco
Re: Adobe Media Encoder won't accept Quicktime reference file
on Sep 5, 2013 at 2:02:15 pm
When I collapse the video, Media Encoder does accept the file. This is just to weird for words !
Perhaps it has something to do with the way pluraleyes handles files ? Thanks for the help in advance :)
Michael Phillips
on Sep 5, 2013 at 3:40:21 pm
PluralEyes should't be affecting QT reference export as it only changes the relationship of the sources. I have recently noticed that a sequence starting with an imported still had some problems in some applications when exported as QT reference. Might be an issue.
Michael
Joshua Menco
on Sep 5, 2013 at 3:46:06 pm
thanks for the info. No still at the beginning though :(
Todd Kopriva
on Sep 6, 2013 at 3:38:04 am
What version of Adobe Media Encoder?
Don't hesitate to submit a bug report:
http://adobe.ly/ReportBug
After Effects team blog
William Busby
on Sep 6, 2013 at 7:30:11 am
Do a video mixdown first then QTref. However... I get the same exact error if there's more than one mixdown which I learned long ago from a short 30 second or so revision that done and tried to re-mixdown just that portion thinking I could save some time. AME didn't like it at all.
Joshua Menco
on Sep 6, 2013 at 11:18:14 am
I tried it, and it does work. Collapse also works.
But I never needed to do this in the past. Ref Exports to AME always used to work just fine.
I'm just one of those guys that can't accept a workaround. I'm such a control freak when it comes to my software; I can't accept bypassing a problem :)
Furthermore, doing a video mixdown takes a while. Doing a qt ref to AME takes only a second :)
Joshua Menco
on Sep 6, 2013 at 11:14:39 am
version 6.0.2.81
Will do that!
Ben Schaefer
on Dec 12, 2013 at 5:06:52 pm
Joshua-
Were you able to resolve your QT Reference issue?
I have the same problem with Avid MC6 and AME CS6. Initially everything worked fine, but after performing the first update of CS6, AME stopped accepting QT Refs from Avid. We run two systems and each have the same software setups. One has the problem and one does not. The only difference is that I have not performed the initial update for CS 6 on system two. However, there are updates that I think we would benefit from, but I am reluctant to update in fear of losing QT Ref from Avid functionality. In the meantime system one still cannot accept QT Refs from Avid.
Any insights?
Joshua Menco
on Dec 12, 2013 at 6:03:53 pm
I never pinpointed the problem. However I have my suspicions.
1: I have a feeling that perhaps an update for quicktime messed everything up since, if i'm not mistaken, AME relies on QT to open the QT refs from avid.
2: If I recall the order of events correctly, things started going haywire after an AME update, just as in your case.
I tried many things to resolve the issue but in the end it drove me so bonkers that I just decided to do a clean install of macintosh, Avid MC7 and Adobe CS6 master collection after which I updated everything as needed (mac, itunes, qt, adobe etc.). Everything works fine now.
This leads me to conclude that none of the updates (qt, AME) necessarily messes things up. It's probably just some buggy thing that you don't even want to understand the workings of but it must be something like: If Jupiter is aligned with mars, you have seen at least 2 hedgehogs in the past year crossing the road or have petted a goat with your left hand on a friday, you shouldn't install AME updates. Seriously, my best guess :P
Spent 2 hours chatting with adobe and they couldn't even fix it.
My advice:
Fresh install of you os and software.
Always run your OS and software from one hard disk and store your data on a separate disk.
This way a fresh install is a simple and painless operation.
Sorry that I couldn't give you good news!
Michael Phillips
on Dec 12, 2013 at 6:11:11 pm
Have you installed QuickTime 7 player? I have the same issue on one my systems that does not have it, and OSX QT player does not see the codec, but if I drop the QT reference in MPEG Streamclip, it sees it just fine. I hear Mavericks is even more stringent on what it considers codecs and in many cases does a transcode to ProRes or H.264 before seeing it in the player.
Michael
Ben Schaefer
on Dec 12, 2013 at 6:21:08 pm
This is very helpful actually. I know now that I am not the only one this drove crazy. I will start the process of re-installing. I wish it didn't have to come to that, but a man's gotta do what a man's gotta do.
Thanks for the time and good luck!
Josh Aucker
on Jul 12, 2018 at 3:36:44 pm
I am having this problem on PC. Did a fresh install of the OS help anyone resolve it on their PC. I am on a brand new computer which makes it more frustrating. AME 2015.2 works but anything after that does not except the QT References. But I have other Computers that will its just that they are not the editing computers.... Go figure....
Thank you all!
Joshua Menco
on Jul 12, 2018 at 8:47:14 pm
Wow! I posted this a loooong time ago ☺
If I were you I would try a few things.
1: install the latest version of quicktime pro for pc
2: see if mpegstreamclip accepts the qt ref
3: install an older version of media encoder in addition to the latest version. You can easily do this by opening the creative cloud desktop app, scrolling down to Media Encoder, clicking the dropdown menu and selecting "previous versions"
Good luck!
Michael Phillips
on Jul 12, 2018 at 9:20:49 pm
On a somewhat related note - I have eliminated .mov from most of my workflow. From Media Composer, starting with a fully unrendered timeline, exporting as MXF OP1a (DNxHD /HR codec of choice) is a faster process with fewer steps compared to rendering, mix-downs, etc. See second half of my blog with some time examples and other benefits:
http://24p.com/wordpress/?p=278
Something to consider in the workflow. With later versions of MC, AMA export is also part of normal export so in theory, you should be able to create a "send to" right to your watch folder from the bin.
Michael
