Weird One-Transcript not visible when open
Scott Davis
on Aug 27, 2013 at 3:19:36 pm
When I go to open one particular transcript (doesn't happen to others) it says it is open but the transcript is not visible at all. Any thoughts?
Scott Davis
View Scott Davis's profile on LinkedIn
Michael Phillips
Re: Weird One-Transcript not visible when open
on Aug 27, 2013 at 4:29:45 pm
I am assuming you mean in the script window after opening a .txt file? What happens if you click in the window or do a "select ALL" in the window - is there something there? If so, select all and go to edit menu and change font. Changing color "might work". If not, select all, then do a command-x. Go to the original text file and copy the text, then past back into the script window to see if that helps.
Michael
Scott Davis
on Aug 27, 2013 at 4:31:36 pm
The script window doesn't even appear. I went back and re-did the script and the new one works fine.
Scott Davis
