Fonts in MC PC/Mac
Chip Hess
Fonts in MC PC/Mac
on Aug 19, 2013 at 1:33:33 pm
So I brought a project home to my Mac-based system.
This was created on a PC station.
I go to change some text in Marquee, and get the message regarding
subbing out some missing fonts.
Thing is, I believe have those fonts installed.
Is there a way to find out which font MC is telling me is missing?
I frankly don't recall which I used awhile back.
Which begs the question, what font location on Mac
does Avid draw from?
Michael Phillips
Re: Fonts in MC PC/Mac
on Aug 19, 2013 at 1:38:15 pm
As far as I know, it uses the same font collection that is managed by the OS and used by every other application. The issue between PC and Mac fonts, is despite having the same name, there may be a different ID associated with them that would cause this to happen. You might want to try "sequence report" (right click sequence in bin) which is designed to give a report of plug-ins, etc. that are needed to conform the sequence. I can't recall whether fonts are included in that report. If they are not, they should be (as well as font vendor and any other info that can be gleaned).
Michael
Michael Phillips
on Aug 19, 2013 at 1:47:44 pm
Well here is a sequence report for a one event timeline (v7) from an AMA linked R3D file with a simple title from the title tool. While it lists that a "title effect" was found in the sequence, it does not give any further information on font, etc. I am inclined to say it will be the same for Marquee.
Michael
##### Effect Summary for 'Untitled Sequence.01': (8/19/13 9:43:57 AM)
##### Created using: Avid Media Composer 7.0.1.1375
3 total effect(s) found.
3 Segment Effect(s): (3 Video, 0 Audio)
0 Transition Effect(s): (0 Video, 0 Audio)
0 Motion/Timewarp Effect(s)
0 Track effect(s): (0 Video, 0 Audio)
0 Audio Pan/Volume effect(s)
Some of the effects are nested inside of other effects. Total nested effects: 1 (1 Video, 0 Audio).
0 precompute reference(s) found.
----- Effect breakdown by effect type: -----
(1) Image : Color Adapter (Advanced KF)
(1) Reformat : FrameFlex (Advanced KF)
(1) Title : Title (Advanced KF)
############################## End Effect Summary ##############################
##### Effect Location Info for 'Untitled Sequence.01': (8/19/13 9:43:57 AM)
__ TRACK __ __ START TC __ ___ END TC ___ __________ EFFECT NAME __________
V1 01:00:00:00 01:00:06:12 Image : Color Adapter (Advanced KF)
(V1) 01:00:00:00 01:00:06:12 Reformat : FrameFlex (Advanced KF)
V2 01:00:00:17 01:00:01:21 Title : Title (Advanced KF)
Effect Location Summary:
############################## End Effect Location Info ##############################
##### Clip and Source Summary for 'Untitled Sequence.01': (8/19/13 9:43:57 AM)
########## Source Clip List: ##########
1 clip found.
____ INFO ____ __ TRACKS __ __ OFFLINE __ __________ CLIP NAME __________
V1 A1 R075_C006_12090E_001
########## Tape Source Info: ##########
No tape-based sources found.
########## Imported Source Info: ##########
__________ IMPORT PATH __________
file:////Volumes/LaCieTB/mortician/R075_1208XV.RDM/R075_C006_12090E.RDC/R075_C006_12090E_001.R3D
############################## End Clip and Source Summary ##############################
Chip Hess
on Aug 19, 2013 at 1:54:47 pm
Thanks Michael, that's pretty much what I figured.
That font info would be useful in these situations, yes!
Glenn Sakatch
on Aug 20, 2013 at 4:22:02 pm
i thought the error message it gave out listed the name of the missing font.
Has that changed, or am i thinking of a different program?
Glenn
Chip Hess
on Aug 20, 2013 at 4:39:35 pm
At least in this instance, no font name was referenced.
Michael Phillips
on Aug 20, 2013 at 4:42:04 pm
When you select "recreate title media" does it offer up a nearest alternative or the one that it is looking for?
Michael
Chip Hess
on Aug 21, 2013 at 4:35:35 pm
Nearest alternative, which was Times Roman - nothing like the original.
I have since moved back to work and wrapped it up, though.
Thanks all!
