Rough Import from AE
Chip Hess
on Jul 30, 2013 at 8:28:15 pm
I am creating very simple animated lowers in After Effects.
When importing into MC, I get very crunchy edges.
Nice and clean in AE, but text looks awful in the Avid.
AE settings are best quality, 720X486,
RGB and Alpha. I have tried Animation codec
and AVI, same result.
Import settings in Avid are 601, no resizing,
lower field first(DV rez)
This happens once in awhile and I need
to correct, thanks!
Richard Sanchez
Re: Rough Import from AE
on Jul 30, 2013 at 9:15:57 pm
Are your playback settings set to Yellow / Green? Or Green / Green?
Richard Sanchez
Los Angeles, CA
"We are the facilitators of our own creative evolution." - Bill Hicks
Chip Hess
on Jul 30, 2013 at 11:31:31 pm
Which playback settings, where?
Pat Horridge
on Jul 31, 2013 at 8:29:19 am
Bottom of timeline has the playback quality setting. anything less than full may give poor results. Also DV res isn't ideal as it's 5:1 compressed (but the alpha should be uncompressed so it should look reasonable)
Chip Hess
on Jul 31, 2013 at 2:48:05 pm
Already set at best, thanks.
I am stuck with DV at work - for now,
and the monitor situation here
is not the best.
I viewed on my external NTSC monitor
at home and it looks fine.
I gather it is the computer monitor
color space difference. It's odd,
as this has happened previously
but does not always manifest.
