Safe to open Bins from MC 6.5 or 7 on MC 5.5.2 ?
Nina Lucia
on Jul 10, 2013 at 5:35:59 am
I'm about to start editing a low budget feature and I have MC 5.5.2. We want to get an assistant started on another, separate, system. Is it safe for me to use bins in MC 5.5.2 that were created in 6.5/7? I've read that using 6 and 5.5 is fine, just checking for the others in case we have to use a newer version.
Pat Horridge
Re: Safe to open Bins from MC 6.5 or 7 on MC 5.5.2 ?
on Jul 10, 2013 at 8:20:33 am
No the changes in V7 means bins can't go back unless you have the latest patch update. Pretty sure there were releases recently for V5.5 V6.0 and V6.5
You need to download and install that latest patch to get bin support.
Also with V7 you get a lot of new features that won't be supported in V5.5 so you need to manage that as well.
Graham Tees
on Jul 10, 2013 at 8:29:52 am
I suggest you have a look at this thread:
http://community.avid.com/forums/p/120486/694429.aspx#694429
Pat Horridge
on Jul 10, 2013 at 11:23:57 am
Check this Avid link
http://avid.force.com/pkb/articles/en_US/compatibility/Sharing-or-moving-bi...
To share bins and projects we recommend:
Media Composer 5.5.3.7, Symphony 5.5.3.7, NewsCutter 9.5.3.7
Media Composer 6.0.4, Symphony 6.0.4, NewsCutter 10.0.4
Media Composer 6.5.3, Symphony 6.5.3, NewsCutter 10.5.3
Nina Lucia
on Jul 10, 2013 at 8:39:46 pm
Okay, thanks.
Grabbing 5.5.3 now.
Ethan Griffith
on Mar 9, 2017 at 4:22:05 am
Nina,
Did this patch solve your issue for 5.5.2?
Ethan
Nina Lucia
on Mar 9, 2017 at 7:32:14 am
I believe so. I don't think I went up to anything higher at that time and I definitely shared bins with MC 6.5.
You can download 5.5.5 now and that will work. I just edited a film using 5.5.5 that was started on MC 8. I created a new project and copied in the bins and it worked fine.
