Symphony Using ARRI MXF Plugin For P2/AVC-Intra
Robert Ober
on Jun 29, 2013 at 2:53:10 pm
Hello Folks,
This was happening with 6.5.2x and is still happening with 6.5.3 . I tell Avid to AMA link to a Contents folder using link to volume and I get errors that it cannot link to 36 files (or whatever the number is). The console says:
Link To AMA Volume -> /Volumes/max3av/Video/CONTENTS/AUDIO/
MVP Used:[ Plugin Name = MVP_MSP_ARRI_MXF © 2011-2012 Hamburg Pro Media GmbH. All rights reserved. Version = 1.0 ]
MSP Used:[ Plugin Name = MVP_MSP_ARRI_MXF © 2011-2012 Hamburg Pro Media GmbH. All rights reserved. Version = 1.0 ]
Link To AMA Volume -> /Volumes/max3av/Video/CONTENTS/VIDEO/
Kinda weird, wouldn't you say?
Seems like I saw something a while back about editing a preference file. I am guessing the ARRI plugin install hosed something.
Ideas? Comments? Snide remarks?
Robert A. Ober
Michael Phillips
Re: Symphony Using ARRI MXF Plugin For P2/AVC-Intra
on Jun 29, 2013 at 3:11:05 pm
Are you selecting the Arri plug-in first, then trying to open P2/AVC? Be sure to select AMA plug-in manually. v7 brings an autodetect feature with it that is really hit and miss, so remember to select plug-in first.
Michael
Robert Ober
on Jun 29, 2013 at 4:11:45 pm
[Michael Phillips] "Are you selecting the Arri plug-in first, then trying to open P2/AVC? Be sure to select AMA plug-in manually. v7 brings an autodetect feature with it that is really hit and miss, so remember to select plug-in first."
Nope not selecting the ARRI plugin. Don't think I know how. Never had to select a plugin in earlier revisions.
Will try to find how to select an AMA plugin manually and try that. I can AMA link files but not Volume as before.
Robert A. Ober
Robert Ober
on Jun 29, 2013 at 4:29:46 pm
[Robert Ober] "Will try to find how to select an AMA plugin manually and try that. I can AMA link files but not Volume as before."
So of course there is a dropdown UI when linking to AMA FILES to choose the plugin (never needed to do that) but not linking to AMA VOLUME. Did find a Digital Rebellion article that does mention the ARRI MXF taking precedence for some reason.
Would like to resolve this for VOLUME mounting if anybody knows a way.
Robert A. Ober
