Crashing when tring to install Media composer 6.5
Vasja Mihelcic
on Jun 24, 2013 at 10:30:12 am
Hello,
I have problems installing Avid Media composer 6.5. It crashes upon the process of installation.
I,m running iMac i7 3,4 Ghz intel Core, 32 GB 1600MHz, Fusion drive (Late 2012) OS x 10.8.3
Any idea?
thx
VM
John Pale
Re: Crashing when tring to install Media composer 6.5
on Jun 24, 2013 at 2:56:23 pm
Copy the installer from the disk image you downloaded to your desktop. Unmount the disk image.
I had the same problem. Worked fine after copying to the desktop.
It's a bug. Avid is aware of it, but doesn't know what causes it yet. Doesn't happen to everyone.
Vasja Mihelcic
on Jun 28, 2013 at 7:00:54 pm
I did it again manually and it worked...bizare, but thx anyway.
Kendall Kaiser
on Dec 30, 2013 at 4:19:14 pm
I've run into this several times with 6.5.4 on osx.8.5 and 8.4. I'm trying the copy to desktop to fix it.
Thanks for the info!
