removing spot with Paint Effect
Avi Lev
on Jun 23, 2013 at 3:56:00 pm
I'm trying to remove a spot from the frame using the Avid Paint Effect.
But it's not so easy on handheld shots. The spot moving fast all over the frame. I tried the Tracking and for some reason it didn't work.
Any Idea how I can fix this problem?
Michael Phillips
Re: removing spot with Paint Effect
on Jun 23, 2013 at 4:15:59 pm
Have you tried scratch removal instead to see if that works any better?
Michael
Avi Lev
on Jun 23, 2013 at 6:46:00 pm
THANKS MICHAEL, I'll try and let you know. Does it have tracking tool as well?
Avi Lev
on Jun 25, 2013 at 8:54:29 pm
I tried with the scratch removal with out much success. Since the spot on the screen is bouncing as fast as ping pong ball the tracking tool is not fast enough to capture the speed. This is how I understand it.
