Importing media into MC 6.5
Victor Vazquez
on Jun 23, 2013 at 1:44:33 am
Hello,
I am very new to using Avid (I'm using Media Composer 6.5) and I'm not able to import any media into my bins.
When I try to import, the message "There are no media drives available. You will only be able to import shot logs." appears. Then when I go to the Select files to Import dialog and select a media file to import, either nothing happens or the message "You cannot import this file into a bin. See the documentation for information about transferring media files." appears.
Why am I not able to import these media files into the bins? And how can I go about to import them into the bins?
Victor Vazquez
Michael Phillips
Re: Importing media into MC 6.5
on Jun 23, 2013 at 3:29:35 am
Make sure your drive have read/write permissions.
Michael
Victor Vazquez
on Jun 23, 2013 at 4:07:44 pm
Hi Michael,
When I open the program the message "No media can be written to any mounted drive. Please check write permissions." appears. I'm wondering how I can change these settings. When I click Get Info on my drives, it appears that I already have read and write privileges.
Victor
Michael Phillips
on Jun 23, 2013 at 4:15:04 pm
If OSX, I know it resets read/write after a "check permission" is done from disk utility. I would start the process again - in disk utility, check permissions. Once complete, get info on drive and set read/write for everyone.
Michael
Victor Vazquez
on Jun 23, 2013 at 5:36:59 pm
I verified and repaired disk permissions then added read and write privileges for everyone, yet the program still cannot import media.
Victor
Michael Phillips
on Jun 23, 2013 at 10:57:13 pm
Hmmm... This happened to me once, but I can't remember exactly why it started working again. Check media creation settings and make sure none of the drive filtering is on.
Michael
Victor Vazquez
on Jun 23, 2013 at 11:49:18 pm
I have all of the Drive Filtering and Indexing setting unchecked.
Victor
Michael Phillips
on Jun 24, 2013 at 12:56:26 am
I'm running out of ideas... perhaps try uninstalling and reinstalling the software?
Michael
Victor Vazquez
on Jun 24, 2013 at 2:38:41 am
The problem was that the program wasn't recognizing my Mac Hard Drive as a drive. Now I'm using an external HD and AVID MC is up and running :)
Victor
