Really weird issue with audio imported to Avid MC!!
Erinnisse Heuer
on Jun 22, 2013 at 9:24:04 pm
I have just received a final mix from my sound designer to lay into my pic-locked sequence in Avid MC 6.5 and it will only play back certain parts of the stereo mix! And what's doubly weird is, the audio meters are reading that there is sound where it plays back silent.
I tried exporting to see if QT would playback the audio, but it still doesn't work.
I can hear all the sound in iTunes and out of the Finder, if I play the file solo in QT, but not in or out of the edit.
This has happened once before but it was a singular spot and easy to remedy. This is throughout the whole piece!
Thanks for any help!
Erinnisse
My specs are:
Duel 2.8 GHz Quad-Core Intel Xeon, OS 10.7.4, Aja 3, Media Composer 6.5
tupeloproductions.com
Owner/Editor/Producer/Director
Tupelo Productions, LLC
Michael Phillips
Re: Really weird issue with audio imported to Avid MC!!
on Jun 22, 2013 at 10:32:44 pm
Is it a stereo mix? What happens if you only play A1 or A2?
Michael
Erinnisse Heuer
on Jun 22, 2013 at 11:04:35 pm
Problem seems to have been solved! I needed to change my audio settings from default pan centered to L / R.
