What is the best way to export for BluRay and DVD
Dave Edwards
on Jun 16, 2013 at 8:39:18 am
I'm new to Avid and at present I'm exporting projects as Quicktime - "high" quality, not single pass, and then importing this into DVD Architect to make DVD or BluRay discs. Is this a good way to proceed or is there a better approach which will optimise picture quality?
Job ter Burg
Re: What is the best way to export for BluRay and DVD
on Jun 16, 2013 at 10:09:23 am
Rule of thumb: do not use the Avid to convert upon export, but rathe do a Same As Source export from Avid. This simply keeps codec and resolution as they are, just rewrapping your stuff into a QT container.
Then you must find out which luma level range your BD or DVD encoding application is expecting.
See:
http://www.jobterburg.nl/Publications/601_709_RGB.pdf
for an explanation of the import/export settings in Avid MC regarding luma level range (16-235 versus 0-255).
Dave Edwards
on Jun 16, 2013 at 10:29:15 am
Thanks, Job,- I'll look at this.
