Globally Remove effect
Greg Cohan
on Jun 12, 2013 at 6:20:31 pm
Is there a way to globally remove effects from a sequence?
Tried
Mark I/O
Select track
Remove Effect Fast Key
But only removes clip you are parked on.
Working on 6.5.2.1
Glenn Sakatch
Re: Globally Remove effect
on Jun 12, 2013 at 8:33:42 pm
not infront of my box, but can't you draw a box to select all the clips in question and either remove effect or event just the delete button?
Glenn
Shane Ross
on Jun 13, 2013 at 12:34:25 am
I just tested it...why yes you can!
This is akin to how you can add effects to clips globally. Lasso, or SELECT...then double click on the effect. It is applied to all selected.
Nice!
Shane
Little Frog Post
Greg Cohan
on Jun 13, 2013 at 1:22:30 am
Thanks that helps.... Ironically I guess I could have crossed the hall and asked you Shane :-)
Shane Ross
on Jun 13, 2013 at 2:26:55 am
Well Greg (who is my current boss), I didn't know this, until now. I knew how to add effects to multiple clips (Titus told me). But I didn't know how to remove them.
Shane
Little Frog Post
