Repetitive Keyframes Marquee Title Tool
Ray Brown
on May 29, 2013 at 5:02:52 am
I'm working in Avid Marquee Titile tool.
I'm creating a series of titles in which each letter of each word spins 3 times as an object passes behind it. Creating this effect for 35 titles each with several letters is proving to be a time-suck.
Is there a "behaviour" type command to simplify this task? Or a script perhaps?
Also, when I Select All Keys and then Paste All Keys. Regardless of where my current position indicator is. Or where I have an in-point set. The keys are always added at the first frame. Can I force addition at a selected frame?
Also, when I expand the timeline and set a key value which causes the property line to extend waaaay up or down out of the field of view. How can I scroll up or down to see that hidden key.
Thanks to all of you for your help and support.
© 2018 All Rights Reserved
