Reconnecting files through unc path
Marc Poirier
on May 25, 2013 at 5:06:22 pm
Hi, i imported a bunch of clips from drive A ... to drive B (accidentaly), then i brought drive A home so I can export my work, but a bunch of files are offline (typically quicktimes) ... I see that the UNC path is linking to the drive (A) .. but when I select relink, relink by.. choose the more column, all the options are greyed out..
any way to relink those files?
thx
Kevin P McAuliffe
Re: Reconnecting files through unc path
on May 27, 2013 at 1:08:53 pm
If you have the files, you can simply copy them from one drive's "Avid MediaFiles" folder to another. Once they are there, and you relaunch, MC/Symphony will rebuild the media databases, and you footage should come back online.
Kevin P McAuliffe
Creative COW Leader
kevinpmcauliffe@gmail.com
Twitter: @kpmcauliffe
Marc Poirier
on May 27, 2013 at 1:24:30 pm
Yes, that should be the easiest solution, but that wasn't working... I was able to reconnect some of them by re-importing the files, then selecting the ones offline and relink. No an easy way to do it, but it was better than re-editing the whole thing!
